Originally Posted By: dishdude
Originally Posted By: NHGUY
Most times,the engine is already made/designed and then dropped in and ooppss....what do we do about this??? A case where the powertrain engineers aren't talking and coordinating with the chassis/body people.
This. Top mounted cartridges are the way to go.
I’m surprised this isn’t standard across all makes/models. This is just brilliant!
No thank you! That would be a mess to change...unless it drains back into the crankcase, but then it's sucking all the dirt that builds up in that little channel down into the motor...and you better have a good ADBV.
This is an oil filter done right -
I miss that from my old TDI. But, there was an issue, initially, the cartridge filter allowed too much oil to drain back, so the oil filter manufacturers such as Mann, added a dam to it, which effectively reduced the oil filtration flow surface area, to prevent oil draining back down, so it became position specific filter.
But the VW ea888 gen 1, does have a top mounted filter with a separately attached ADBV mechanism on it.
No mess when you remove the oil filter.
You also cannot "prime" the oil filter with fresh oil either.
I honestly didn't mind the bottom mounted oil filter on my 2008 Passat. The oil filter center column went back to being symmetrical.
The oil in the housing is easy to drain, though I had to drive the car up on ramps, which the bumper barely cleared with my lowered car.
