Changing Rear Differential Gear Oil
Yes. All of the heavier duty applications with or without a TLok spec 75W140 synthetic with the FM additive in the case of TLok.
I dont know what it is with aftermarket limited-slip manufacturers and synthetic lube. It ticks me off a bit because I want a Detriot TruTrac but that requires mineral as well. I think its just because most come with FM additive already in it but they dont come out and say that they blanket all synthetic lubes.
The limited slip I have in an Auburn HP Series, which uses a cone clutch. There is no harm in using a synthetic with that unit, assuming it has sufficient FM characteristic either naturally or added, it will just deliver a reduction in the bias ratio. How much, I do not know. I may soon find out.
I had an inside source at Eaton who once told me that some syns cause problems with Truetracs and some do not. The problem is, they really have not done any studies to determine which is which... at least they claim not to have... and if they know exactly what is causing the problem, they would not share it with me. It's simply easier and cheaper for them to continue to recommend "regular" mineral oil. If a customer ignores the lubricant recommendation, whatever happens is on them. One of the most common questions on the Eaton Tech line concerns sythetic lubricants.
All that said, there are many people running syn in Truetrac diffs. I ran Amsoil Series 2000 in mine with no particular problems and now run the equally slippery LE607 mineral oil (bolstered with a lot of a Moly-like additives) in it, also with no adverse symptoms. WIth some syns, including the factory fill oil Ford puts in the late model F-Series trucks with the S-110 axle that has a Truetrac. The adverse symptom is noise, a squealing in particular. There may be a reduction in bias. Don't let the oil issue stop you from getting a Truetrac, Colton. Even if you have to stoop to a mineral oil. Do Like I did and experiment a little once the unit is broken in on mineral oil.
My opinion as to why Eaton recommends mineral for the Posi is the same. That recommended lube is the one they used for testing to obtain the advertised bias ratio. SInce oils can effect performance and driveability, again, they would rather not experiment with every type of oil to see what works and what doesn't. Much easier to recommend what they know works
Originally Posted By: Colt45ws
Thanks for the info, Jim. It hadnt really stopped me from considering one, just irratated me a bit I guess.
Sorry for than tangent, 'storm.
No apology necessary. Irritates me too, just because they don't really seem to want to find out what works and what doesn't.
Thank you for the info Jim. The truck's new so I decided on making a quick call to the dealer. The partsman's answer, when they service them, he gives the tech what Ford specifies, current recommendation on my truck is 80W90. I told him I would be towing near the truck's capacity, his logic was that Ford wouldn't have recommended 80W90 if it would meet the tow capacity. Which makes sense. 75W140 is specified for the F150 with that gear, but the 4.6L puts a lot more torque then my 4.0L. Jim, to answer the other questions, 1. This boat gets hauled 100Kms twice a year 2.One gets used -15C winters after a few years. I didn't want go any thicker than I had to for fuel economy reasons and I didn't to replace the differential because I didn't go thick enough either.
