When I changed my oil for the first two times I used the ramp, started the car and backed it off the ramps, then shut it off and checked the level. I was bored and reading Castrol's website today and saw this:
"Carefully release the handbrake and allow the car to slowly roll back down the ramp to level ground (do not run the engine at this stage or severe damage will occur)."
Will severe damage actually occur by starting your engine on the ramps to back it down? I never noticed anything the last two times I did it... I don't even see how you can back it down without starting it, because just putting it into reverse doesn't give it enough power to get over the small hump to let them off the ramps.
