Didn’t know that! Thank youI too wondered how to make it pop up like on the computer but after clicking the blue name it brings it up.
This!Wood heat as the only heat source is a non-starter for any mortgage lender. So selling will be very difficult.
I would address any drafts in the house first because that directly impacts occupant comfort. Perhaps take advantage of a state program?
You could just upgrade the existing boiler or transition to gas or a heat pump depending on which is cheaper. Power vent nat gas furnaces can reach over 95% efficiency.
Remember, address the air leaks first if you can. Air leaks cost you $$$$.
OP said busted pipe in a wall so it hasn't been running.Why are you using space heaters instead of just running the oil boiler?
Not having hot water circulating through the piping & radiators in an old/drafty house is a recipe for frozen pipes.
or turn phone to landscape.Didn’t know that! Thank you
I’ve never even tried that before. It worked! Thanks man. I’ll do that when it’s location dependent so I’m not asking around like I did.or turn phone to landscape.
Wood needs to be stoked, can run out, fire risk. Can you convert to a gas furnace?I hope this is the right place to ask this.
I need some perspective.
I live in a 1947 brick house. It has an oil-fed boiler. Its currently down due to a busted pipe in the wall. We primarily use space heaters (even when the boiler works). Only to use the big heat when temps dip below 25⁰. We also have a typical fireplace.
I have a classic wood stove I bought years ago but never implemented. I was considering putting it in the basement directly below my living room. That would however require removing the oil tank thats in the same location thus permanently disabling the boiler.
The boiler is old...and seemingly every year something needs to be addressed.
Whats the hives opinion...convert to wood heat or fix the boiler?
I always found freezing rain / ice and the outdoor heat pump is NOT a good combo, Gotta keep ice off that thing.It says right there they're in Maryland.
It is getting into single digits overnight in MD currently. Heat pumps will be running in "emergency" heat mode and the electrical usage will be outrageous.
Don't you have the option for your own propane tank ? That's very common around here outside of cities where there's no natural gas lines run in the streets. They use the same furnace (with appropriate modifications), water heater, etc as natural gas serviced homes.Not all areas of MD have natural gas. And our governor and green representatives want to ban natural gas furnaces, water heaters, stoves, and ban any new gas lines run in the state.
Good question, but if I have to have propane delivered instead of oil delivered I don't see the point. After state energy tax, one costs about the same as the other.Don't you have the option for your own propane tank ? That's very common around here outside of cities where there's no natural gas lines run in the streets. They use the same furnace (with appropriate modifications), water heater, etc as natural gas serviced homes.
Put a roof over it. The cold climate models also have defrost mode.I always found freezing rain / ice and the outdoor heat pump is NOT a good combo, Gotta keep ice off that thing.
Hard to give advice of heating a home as it all depends on the area and the price of the fuel in that area being used.
I found living in the Carolina South, a 160 mile move from inland to the coast changed everything.
After I moved to the coast heat pumps, electric hot water heaters and stoves are the norm when inland it was natural gas everything.
Yes, but propane has a few other benefits. For one thing, it eliminates an old oil tank in the basement or next to the house. Other benefits are that you can cook with it, dry clothes, etc. electric rates are rising rapidly in many parts of the country, so if you are interested in shedding some electrical load propane is one way to do that.Good question, but if I have to have propane delivered instead of oil delivered I don't see the point. After state energy tax, one costs about the same as the other.
I’m sorry but that makes no sense to me. You’re better off with the oil or natural gas furnace and a stand alone AC system. A heat pump unit is more costly than a standard AC unit and is a nonstop running, defrosting, needing electrical backup strips, noisy-worrisome appliance that can be damaged during in an ice storm…all winter long.You should get a heat pump. It's more efficient than your space heaters and works as a great AC in summer too.
BUT, keep the oil heat as a backup. Cold spells make heat pumps less efficient and that's when you need them the most.
I take it you have no real world experience with modern heat pumps? I'm not trying to come off as rude by saying that but I see these kind of comments often from those that haven't been around modern heat pump technology.I’m sorry but that makes no sense to me. You’re better off with the oil or natural gas furnace and a stand alone AC system. A heat pump unit is more costly than a standard AC unit and is a nonstop running, defrosting, needing electrical backup strips, noisy-worrisome appliance that can be damaged during in an ice storm…all winter long.
