Never tried this job before, want to tackle it, if I back away at least I can rotate the tires.
That being said, I've got on hand a 2 ton floor jack, naked V6 4x4 Escape is 3340 lbs or so if I recall, I'll empty the [censored] out of it before I start to be on the safe side. I also have 2x2 ton jack stands. Also have heavy duty ramps.
The maintenance manual, btw, only assume you jack car up using their jack, to replace 1 tire. I'd like to rotate if I could, otherwise this wouldn't be an issue. So there is really only one spot near each tire to jack/support from what I can tell.
Issue: How the heck does one safely jack up the Escape and then place the stands in the correct location? Not really an easy fit, can't get it to work. Saw a picture of someone else with same issue in Escape forums using a 2x4 on what looks like sheet metal to use floor jack, then placing jack stand at the spot (arm joint) recommended by Ford in the manual.
Anyone hear doing this on your Escape/Mariner/Tribute? earlier (2005 & earlier) models?
My plan , because of this, was to drive both wheels of one side onto ramps (lets say passenger side), block the opposite 2 wheels (driver side), place jack stands at correct spot passenger side now support, remove ramps & tires, and then try to tackle front brakes, then rotate tires on that side. Bad idea?
Also, anyone use ACDelco ceramic pads and their rotors (front disc)? Anything better for similar price?
