Originally Posted By: daves66nova
the fluid does look brownish, so i'm thinking of doing a few drain and refills.So there is a diff to drain on this car?
The differential is in the center where the front axle joins in, its right behind the transmission. You can see the drain plug is facing the ground, you need a hex tool (don't remember the size, it might be 10mm). Loosen the fill plug (faces the firewall) before loosening the drain plug. It takes 1.5 quart and uses ATF. Fill it when its ground level, I just pump the fluid into the fill hole until it spills out of the hole.
