I have a 2002 Ford Explorer with 60,900 miles that I purchased new back in the day. I recently got auto maintenance do it yourself bug and it's fun to be working on cars again.
Ford spec'd Mercon in the transfer case rather than the Mercon V used in the automatic transmission. Since Mercon has now gone to the happy lubricating fluid hunting grounds I used Mobil 1 Synthetic ATF that fulfills the Mercon V standard, and several others (see here).
The old fluid was a medium brown rather than red or pinkish of new ATF. It didn't smell burnt, but certainly didn't look good. I have never towed with the Explorer and Ford has no interval on changing it. Looks like to me 60,000 miles was a bit long for it.
Next up are the limited slip D4 rear differential spec'd for 75W140 synthetic , the front differential spec'd for 80W90 and the automatic transmission spec'd for Mercon V.
I thought I would try Amsoil 75W110 in the rear as I use the explorer in light duty, Amsoil 75W90 in the front and use Mobil 1 synthetic ATF in the auto transmission. I suppose I could be talked in to using Amsoil ATF or Redline D4 for the transmission instead of Mobil 1.
Rumple
Rumple
