This is our beater with 211k miles.
IDK when the cabin air filter was last changed, but it was pretty nasty. Was Hyundai OE, and had a nice plastic frame around it.
Air filter in car was OEM - also unsure when last changed - didn't look too bad, but went ahead and changed it anyway...Lots of debris/leaves/sand was vacuumed from air box. Felt good doing that.
The new Mann seems very well made, and fit tight and nice.
I used Mann for both filters, and both were US made;
changing the cabin AF was a real PITA as getting the glove box clips and retainer was extremely annoying; after that all went quick...
(I also changed the power steering fluid partially with MaxLife ATF which meets Hyundai req'd specs for PS fluid) using the mighty vac, but even after swapping out 1.25 qts (and turning steering wheel lock to lock each time), the fluid was still darkish/brown - I ran out of time, but will complete later. Hopefully the 3 qts of new MaxLife ATF i have left will be enough to replace most of the old PS fluid - it was a slow process...perhaps turkey baster would have been faster.)
A few pics I took during filter(s) change the process:
