I change mine every 50k-100k miles
I could probably go longer, but the Math works
I do lots of Highway miles
My father and friends think I’m crazy but I shop vac out the lower air box when replacing the air filterI just take my engine air filter out and blow it out with clean compressed air, from clean side to dirty side. Lots of dust comes out, but I make sure the clean side stays clean. Then I use a vacuum to clean the clean side before putting it back in. I never see any dirt or dust in the intake tubing.
lol what?!I read somewhere that when you open the air box to clean the air filter, you introduce more dirt into the engine then the filter would have done in its entire life? So should I put brand new air filter and then leave it alone for 1 year?
I always have done that...I even wipe my cabin filter boxes out with a microfiber cloth. Why not?My father and friends think I’m crazy but I shop vac out the lower air box when replacing the air filter
Tell 'em I'm real nuts because I wash mine out with soapy rags and "wipe-rinse" it.My father and friends think I’m crazy but I shop vac out the lower air box when replacing the air filter
Wasn’t even near needing changed.35K on our '13 GS350 F Sport
I was embarrassed to post the mileage...Wasn’t even near needing changed.
Nah, that's untrue unless the outside of the filter housing is a dirty, dusty mess. So simply wipe it all down with a rag before opening up, especially around the seams.I read somewhere that when you open the air box to clean the air filter, you introduce more dirt into the engine then the filter would have done in its entire life? So should I put brand new air filter and then leave it alone for 1 year?
If you happen to do UOAs every oil change, would watching the silicon levels be a good indicator of when to change the air filter? Any significant uptick in silicon levels be an indicator that it's time to change it?People change air filters WAY too often ... and it can be detrimental to do so.
This is an article written by one of our members (Jim Allen; writer of various automotive articles and published in many magazines and books).
A few key takeaways ...
- 90% of the particulate that a filter will pass happens in the first 10% of it's lifecycle (meaning the more often you change it, the more particulate you allow in).
- as the filter loads, it becomes much more efficient
- the average car filter may have a capacity able to hold many years worth of normal particulate loading; sometimes up to 150 grams
- etc ....
https://www.rv.com/rv/towing/the-truth-about-engine-air-filtersinternal/
Just like changing oil too often is costly, so it changing air filters. And with the added risk of inducing more dirt into the engine.
If you want to mess around with your car, give it a wash instead, and leave the air filter alone!
I'm not an expert, but I would think silicone levels should remain low whether an air filter was at the beginning or end of its life
Previous posts represent sound practice because the posters are thoughtful and knowledgeable.
However, generally speaking, you don't want to let talentless, careless, possibly irate personnel at quick lube joints "check your air filter" for you as they are known to make mistakes frequently.
These mistakes include failing to seat the filter and lid when they're done or, in the case of air cleaner housings like mine, break hold down hardware.
Using cheaper filter elements with questionable performance and fit is also rife.
Yep. My dodge dakota they did not close the box properly. I drove for a little bit and looked under the hood one day. Noticed it. Luckily i did not drive it much as its a 2nd vehicle.Previous posts represent sound practice because the posters are thoughtful and knowledgeable.
What name are you right now?
