Change Hyundai Oil Or Not ?
PNW
Well maintained Hyundai Sonata 2.4L Theta II GFI engine (67,000 miles) current oil fill is : VRP 5W30 (2nd fill) with 3,800 miles and 6 months on it with 85% highway or interstate driving in a PNW moderate climate… I need to make a 600 mile all interstate round trip drive next week , so the question is do you keep the current VRP 5W30 fill and change it when I return OR change the oil before the trip ? Again , a well maintained engine using M1 or VRP 5W30 with a 4,000 mile / 6 month OCI normally. Oil will have approx. 4,400 miles on it and still at the 6 month in use mark when I return … It’s essentially a ‘tweener oil change question.
Don't change the oil. Just change the car
If it were me, I would make the trip and change oil when you get back. Even at the 4400 miles that the oil will have on it when you get back, that is well under the typical conservative oil change interval of 5000-6000 miles that many follow.
I appreciate the replies - this trip’s conditions are going to be an easy , level interstate drive at 80 degrees F . My thoughts are that while even on a Hyundai GDI engine that normally sees a 3,500 - 4,000 mile / 6 month OCI using good synthetic oils - it should be able to handle a 4,400 mile OCI . I’m at 3,800 miles / 180 days (6 months) on the current fill and while Valvoline states 120 days I have to believe it should be able to handle 180 days on the current fill like most everybody else using synthetic oils abides by (i.e. 5,000 miles / 6 months is the gold standard using quality synthetic oils).
Toss up. I think I'd run it and change coming back given it's well maintained.
If it wasn't well maintained then I'd change the oil and filter now.
Month time means nothing under 12 months +. I would run it at that mileage, no turbo and mostly hwy. Valvoline Restore and Protect (VRP) is the cleanest running oil my car has ever seen at my 3,000 mile OCI. Amsoil's redish, ALL other oils are black and VRP is transparent brown. I assume that is what your is too?
Aren't those the ones that randomly blow engines and call for 20wt oil?
Since you have a 30wt in there it's probably fine.
Yes and yes - I ran only one OCI of 5W20 (oil cap stamp) when new before switching to 5W30 synthetic full time which was allowed by Hyundai (along with 10W30).
Yes , exact same oil color description. I would like to think there is not much to clean out (except oil ring carbon) in my engine as dip stick and oil fill hole are bright silver.
Said it before I could. Change the Hyundai. (To something else.)
Happy 4th of July 🇺🇸
OP here - I have to laugh at the good natured sense of humor displayed … People ask me : “Why do you carry a baseball bat in the trunk of your ‘17 Sonata” ? The answer is if the vehicle thinks even for a split second it’s going to go into limp mode - it knows what actions will follow, as I will go full blown Buford Pusser (i.e. Walking Tall movie) on it ! 🤣
