When you change your coolant, should you do it after the motor is warm (and the coolant is, therefore, hot) or when it's stone cold? I sort of think that changing the coolant while it's hot might do a better job of flushing any debris out along with the old coolant, but maybe it doesn't make any difference?
Also, I've seen some YouTube videos that say, after you've refilled with new coolant, set the heater to hot and...
Thank you,
Ed
- Don't turn the fan on
- Turn the fan on low
- Turn the fan on high
Thank you,
Ed
