Looks like another bypass seal area oil leaker.
Yes, modified it a tad. As noted though, same results.Thanks!! Another champ labs leaker. I guess Whip liked my in canister test![]()
I’ve had 2 Frams pass. OG Titanium and a PH10060. Other members have had Ultras pass as well.Isn't this type of bypass valve design used by a significant number of manufactures? Has me wondering if this a common to all?
It's common now to Champ Labs made filters with metal to metal separate/detachable bypass piece. Not all filters have separate detachable bypass piece, many are integrated to dome endcap. And some like OG Ultra with separate bypass piece use/used a gasket type material on dome endcap seal area.Isn't this type of bypass valve design used by a significant number of manufactures? Has me wondering if this a common to all?
First non 7317 or equivalent. Nice catch!It's common now to Champ Labs made filters with metal to metal separate/detachable bypass piece. Not all filters have separate detachable bypass piece, many are integrated to dome endcap. And some like OG Ultra with separate bypass piece use/used a gasket type material on dome endcap seal area.
And another note, topic XL not a 7317 application.
Calculations made in another thread are 10-16%. The gap sizes on that Endurance are two .75”x.020” gaps. Which imo would be a very large media tear.I wonder if the volume of flow that leaks past the bypass seal area is significant enough to be a concern? Any leakage is not ideal, but we would need to know what percentage leaks past the bypass seal vs total flow through the filter to know if this is really a concern.
I was guessing less than 5%, 10-16% is not good at all. This bypass valve design is so common on today's filters, it doesn't leave very many filters left to choose from.Calculations made in another thread are 10-16%. The gap sizes on that Endurance are two .75”x.020” gaps. Which imo would be a very large media tear.
Give it some time … seems like a never ending down trend in manufacturering quality.Any other recent race to the bottom trends in aftermarket filters?![]()
Yes, it's used in a lot of filters, but the leaf springs seem to be made in the Ruffles factory lately. Seems there has been a change in the sheet metal forming quality. Older examples show a smooth sealing surface instead of a highly rough rippled surface. Only way a metal-to-meal interface is going to seal well is if both sides are flat and smooth.Isn't this type of bypass valve design used by a significant number of manufactures? Has me wondering if this a common to all?
Must not be very flat then. It has to be both flat and smooth on both sides of a metal-to-metal interface/seal to work properly. Yes, a gasket is the sure solution. The OG Ultra was the bomb with the fiber sealing ring on the end cap. IMO, it might be easier to simply add a filter sealing ring that fits tight on the leaf spring before installing it in the end cap. I'm sure that could be automated in production.Seems that even the smooth leaf springs can have gaps based on this test by Whip City Wrencher:
