Originally Posted By: cronk
Originally Posted By: tdi-rick
I disagree with the comments on only using Stihl chain.
Any sharp chain cuts the best
Learn how to file, get a couple of spare loops and you'll be set.
I disagree totally. I have a Stihl MS290, when I purchased it, I bought a spare Stihl chain from the dealer. Both the chain on the saw and the extra cut super fast and seemed to hold a sharp edge quite a while. I later needed a replacement chain, bought an Oregon at the local box store. Not only did it cut much slower, it did not hold an edge nearly as long.
After only a couple days cutting with it, went in the garbage can.
Put a Stihl chain on, and it was back to the fast cutting, low maintenance saw I remembered with original chain.
Stihl chain is treated to a higher hardness then most if not all of the other brands, And therefore with proper usage last longer.
