Originally Posted By: PandaBear
Currently my house (2/F, 1500sqft, living room is what they call a "cathedral ceiling" of 2 story tall) has a 100000 btu 4 burner furnace. It would turn on for a few minutes then pause for 15-30 minutes all the time. The biggest problem however is the noise it generates by the blower pushing exhaust through a vent inside the wall between 2 rooms, waking everyone up in the middle of the night. The next biggest problem is the high natural gas bill whenever we use it.
Currently we have a 2.5 ton AC that we just installed last year and use the same furnace blower fan and it is sized just right (IMO), very quiet (the air mover is not the problem, it is the powered furnace exhaust that is loud). So if I go to a small furnace, how many BTU / burners should I look for? Does it make sense to go to 93% or higher efficiency? (I understand that we have to adjust the water condensation in the exhaust but it is right there with the AC anyways).
Should I stay with PSC fan or ECM fan?
Panda,
do you have a single stage furnace? or dual stage?
I can't imagine a 100k single stage, that is a lot of juice, plus you are in a warm zone
you can set the fan speed on the furnace it can be varied by 10% on newer furnaces.
in MI, it is -7F outside and I have a 80k btu furnace in a 2200 sqft ranch.
saying that, I don't think u need waste money in replacing the furnace, but tweak it a little.
how old is it? what brand? is the fan DC or AC?
on a side note I would install a fan on the vaulted ceiling and keep it running to mix the air, where is the thermostat located?
Panda,
