Originally Posted By: MedicRxDoc
The viscosity was 5w30.
I do believe that the Caddy with this engine does spec the GM4718M.
You are right. My caddy requires a synthetic gm specs of GM4718M with the exact same engine as yours.
I never knew why only Caddilac engines required GM4718M while for example the Acadia does not required it. Its the same engine.
If I was you, try one that meets both specs. And check for a new results.
Here's my UOA from my 2005 caddy cts 3.6l vvt:
http://www.bobistheoilguy.com/forums/ubbthreads.php?ubb=showflat&Number=1437323#Post1437323
