I'd run a modern 15w40 or straight 40. I'd only use the 30 in cold weather conditions. I'm not familiar with your crankcase vent system, and don't know if the 15w40 vapors through the turbo would cause a problem. I think I'd try to contact a tech rep at the Cat factory about the 15w40. A CI-4 15w40 is a better oil than a CF 40 wt., and I'd use the better oil except in special cases like a Detroit two-stroke engine (which must only use a CF-2 oil).
Ken
Ken
