Before I do this drain and fill on my wife’s 2013 Honda fit, is there anyone on here who has used the Castrol universal atf/cvt fluid? I’ve used Valvoline maxlife in the past, just curious about this Castrol offering
I have used it in a Mitsubishi Mirage CVT - worked fine and I consider it equal to Maxlife. I mostly use Maxlife but on occasion I will use the Castrol as well as it is often a few bucks cheaper. Use it with confidence.Before I do this drain and fill on my wife’s 2013 Honda fit, is there anyone on here who has used the Castrol universal atf/cvt fluid? I’ve used Valvoline maxlife in the past, just curious about this Castrol offering
Is there a chance the transmission has some issues and maybe was not the fluid? I agree that when in doubt the OEM fluid spec is the better choice - but having used Maxlife in so many different applications in my shop with no issues I will continue to use it where I know it works but there are definitely certain applications where you want a specific OEM fluid spec over universal.I used Maxlife ATF in my old Nissan AT, and it never shifted properly again. Since then, I only use OEM recommended fluid in AT's. I don't know what fluid is recommended in your Fit, but the safe choice, is the OEM Honda fluid.
No atfIs your Fit a CVT?![]()
No atf
