The base oil used (Group III or IV) has nothing to do with the ACEA rating of an oil. A3 is a gasoline extended drain spec. B3 and B4 are diesel extended drain specs.quote:
Originally posted by glxpassat:
I'm bumping this thread since I just bought a case of this stuff. From all of the research I've done, a group III is A3/B3 rated, whereas a group IV is A3/B4 rated and is considered long life.
B4 is the best if you need an oil that meets the toughest European extended drain requirements for automotive diesel engines (like the BMW V8 diesels used in the 7 series), otherwise the rating is irrelevant. A3 is the toughest extended drain spec for gasoline engines (though most all A3 rated oils will also be rated B3/B4).quote:
I was just going by a comment I read by Tooslick where he said the B4 rating was the thing to look for to identify the best oils on the market. I assumed that meant a group IV.
Please bare with me here cause I'm learning. So if B4 is the toughest euro spec, could a group III/non PAO oil meet that? What I was trying to nail down here, is the question at the begining of the thread as to whether BC is a group III or IV oil. I thought it would have to be a IV to meet that spec. But I certainly could be wrong...quote:
As I said, you can't determine the base oil used by the ACEA rating. A B4 oil could be built that has Group III in it.quote:
BTW, I read castrolcanada's descrption of GC and they refered to it as a wintertime oil where extra pumpability is needed. Maybe it's green because it has a little Prestone in it.
