This is my fourth UOA on my 2002 Toyota Ipsum done by Dyson Analysis. Latest results on the right, oldest on the left. The spike in lead is most probably due to my IAC valve cleaning using a TB cleaner just before dumping out this oil. I suspect the TB cleaner also caused the oil to thicken. Im very happy with the fuel economy of this vehicle, it's getting its best ever fuel economy since I switched from Shell V-Power 98 to Caltex Vortex Platinum 98.
Oil
Toyota OEM, Castrol RS 10w50, Castrol RS 10w50, Castrol SLX 0w30
Mileage on car
1072km, 6056km, 11080km, 15973km
Mileage on oil
1072km, 4984km, 5024km, 4893km
Time on oil
1month, 7months, 6.5months, 5months
Make-up oil
none, none, none, none
IR
Soot (St)
44, 0, 0, 0
Oxidation (Oxi)
22, 63, 76, 117
Nitration (Nit)
30, 77, 105, 4
Sulfation (Sul)
18, 40, 75, 86
Metal
Iron (Fe)
6, 11, 11, 11
Copper (Cu)
47, 16, 4, 2
Chromium (Cr)
0, 0, 0, 0
Aluminum (Al)
7, 3, 2, 2
Lead (Pb)
1, 7, 3, 9
Tin (Sn)
1, 5, 1, 0
Silicon (Si)
200, 69, 32, 26
Sodium (Na)
3, 5, 1, 1
Potassium (K)
0, 1, 0, 0
Molybdenum (Mo)
435, 84, 12, 3
Phosphorus (P)
693, 751, 741, 775
Zinc (Zn)
861, 895, 850, 830
Calcium (Ca)
1540, 2568, 2463, 3075
Magnesium (Mg)
16, 117, 174, 124
Physical
Water (W)
N, N, N, N
Fuel (F)
N, N, N, N
Antifreeze (A)
N, N, N, N
Total Base Number (Tbn)
6, 6, 7, 9
Viscosity At 100 C (V100)
9.4, 18.5, 17.9, 13.1
Oil
Mileage on car
Mileage on oil
Time on oil
Make-up oil
IR
Soot (St)
44, 0, 0, 0
Oxidation (Oxi)
22, 63, 76, 117
Nitration (Nit)
30, 77, 105, 4
Sulfation (Sul)
18, 40, 75, 86
Metal
Iron (Fe)
6, 11, 11, 11
Copper (Cu)
47, 16, 4, 2
Chromium (Cr)
0, 0, 0, 0
Aluminum (Al)
7, 3, 2, 2
Lead (Pb)
1, 7, 3, 9
Tin (Sn)
1, 5, 1, 0
Silicon (Si)
200, 69, 32, 26
Sodium (Na)
3, 5, 1, 1
Potassium (K)
0, 1, 0, 0
Molybdenum (Mo)
435, 84, 12, 3
Phosphorus (P)
693, 751, 741, 775
Zinc (Zn)
861, 895, 850, 830
Calcium (Ca)
Magnesium (Mg)
16, 117, 174, 124
Physical
Water (W)
N, N, N, N
Fuel (F)
N, N, N, N
Antifreeze (A)
N, N, N, N
6, 6, 7, 9
