9 98LSC32V Joined Feb 15, 2007 Messages 654 Location Hallandale Beach Fl Feb 16, 2007 #1 My car calls for Mercon 5 only, is it safe to use Castrol Multi Vehicle ATF in the transmission? The specs say it meets Mercon 5 specs.
U unDummy Joined Feb 1, 2003 Messages 8,755 Location RI Feb 16, 2007 #2 Yep, feel free to use the Castrol.
9 98LSC32V Thread starter Joined Feb 15, 2007 Messages 654 Location Hallandale Beach Fl Feb 17, 2007 #3 If I have to add a little bit of ATF can I use Mercon 5, I can't find Castrol Multi vehicle ATF on the shelves? Can you mix them is my question... I know you aren't supposed to mix Mercon and Mercon 5 at all.
M MaximaGuy Joined Sep 20, 2003 Messages 1,803 Location Austin, TX Feb 17, 2007 #4 I looked at the Castrol MV ATF in Walmart and it clearly said it is NOT suitable for MerconV and Mercon SP. Please recheck the label .. it is good to recheck.
9 98LSC32V Thread starter Joined Feb 15, 2007 Messages 654 Location Hallandale Beach Fl Feb 17, 2007 #5 You must be looking at some different ATF because: http://www.castrol.com/liveassets/bp_int...Vehicle_ATF.pdf That's the one I just flushed my car with.
M MaximaGuy Joined Sep 20, 2003 Messages 1,803 Location Austin, TX Feb 17, 2007 #6 The one I saw said "Domestic MV ATF", don't know what that domestic meant.
U unDummy Joined Feb 1, 2003 Messages 8,755 Location RI Feb 18, 2007 #7 Grab a picture of that label.
9 98LSC32V Thread starter Joined Feb 15, 2007 Messages 654 Location Hallandale Beach Fl Feb 21, 2007 #8 ttt, so can I mix regular Mercon 5 and Castrol multi vehicle ATF if I need to add some ATF?
