Originally Posted By: LeakySeals
Add Syntec to the evil Castrol list.
On a several forums I'm a member of engines with high mileage (200-300k) are burning oil and being torn down for suspected mechanical problems. On a Toyota forum usually what is found are hardened deposits consisting of varnish and flashed oil blocking piston oil returns, rings, etc. I ask every time what oil was used. Usually Castrol GTX and the most recent was
Castrol Syntec. In the recent teardown @318k it was the same engine as my camry.
Castrol Syntec was used most of its life @5k intervals. Was a highway car which ran 200 miles a day so heat was definitely a variable. Upon teardown there were no mechanical problems, just varnish and hardened carbon blocking piston oil holes. Pictures show a clean but heavily varnished (IMO) engine. Same with the 98-02 Corollas. Clogged piston holes is all thats wrong with all the oil burners in these years. 50+% of them ran Castrol gtx for extended periods."
In pictures..
Looks great up top
Bearings look great too. It still had to be torn down anyways. Why?
Getting closer to hotspots we start to see why.
I`d be curious to know the oci`s here. I`m willing to bet extended oci`s (especially on dino) are to blame.
