First this is about Honda / Acura
Im sorta confused here.
From what I read you can use Castrol® Transmax™ Full Synthetic Multi-vehicle
in Acura and Honda and it says DW-1... read on..
Castrol has.
Castrol® Transmax™ Full Synthetic Multi-vehicle is a technologically advanced, low viscosity formulation specially designed to deliver maximum fuel efficiency for modern automatic transmissions. It is blended with premium base stocks and is fully approved by both Ford and GM for use in vehicles requiring their latest ATF specifications. Exceeds requirements of JASO-1A and recommended for a wide range of import vehicles.
As you can see is Full Synthetic... & Transmax Multi Import Is NOT.
Seems very similar to what the back of this bottle says, about on HG DW-1 about
low viscosity formulation and Low viscosity formula for maximum fuel efficiency &
smooth transmission performance
Superior high temperature protection to effectively resist oxidation
Not the same but very similar
and it says in data sheet Honda Acura Z1 and DW-1
Honda/Acura
ATF-Z1, ATF DW-1, (except in CVTs)
but in other 2 products its only DW-1 for Honda and only the Full Synthetic is for both
Honda and Acura.. Hmmmm
Perhaps pics from the PDF are better, and my point is I have never seen this product say HONDA ATF Z1 & DW-1, I have only see that in the Transmax Multi Import ATF..
So if you had to use 1, what do you think has the better specs as far was is posted.
Strange both work for Honda DW-1 but might have Different shear cSt and Viscosity and Flash Poin other tech stuff.
read on.
Now here is the Castrol Transmax Multi Import ATF, that says for HONDA , Toyota , Acura on the bottle.
I find this odd.. I would think the Full Synthetic would be a stronger and overall better product... but I do not know about the vst and flash point info.. what is the better test info.
Strange its DW-1 is not listed for Acura. I thought they were the same as Honda.
Here is the test info that some tech savy people might be able to make heads and tails about what would be the better ATF for a Honda.
Now just for the heck of it , the Castrol High Milage Multi ATF...
Looks like they added DW-1 to the list.. however here is the info about the fluid so a tech savy person should be able to say what would be the best choice out of the 3 list products here that all say DW-1 For Honda and only 1 say DW-1 For Acura and that was the Castrol® Transmax™ Full Synthetic Multi-vehicle, has Honda and Acura listed as approved for Z1 and DW-1 and the other 2 products have Honda listed as Z1 and DW-1 but Acura only Z1.. Very ODD...
here is the test info the tech savvy people will be able to make heads and tails from.
I always use Real Honda Z1 and now Honda DW-1 however the price of Honda DW-1 is just killing me.... and Im looking for somthing else.
So from looking at all the info and this is for Honda people... what ATF looks like to be the better Fluid.
The Castrol® Transmax™ Full Synthetic Multi-vehicle
that is listed for DW-1 for both Honda and Acura and is FULL Synthetic
or
that is not a Full Synthetic or even a Syn Blend that is Honda DW-1 but not listed for Acura.
or
that is listed Honda DW-1 but not for Acura
and is not a Full Synthetic or Syn Blend.
So what has the better scores when it comes to cSt and Sheer and Flash Point ECT???
I would think the Castrol® Transmax™ Full Synthetic Multi-vehicle
but Im not really a expert and have always use Honda Genuine ATF Z1 or DW-1
Sorry the post is long but I wanted it show all aspects as many Honda and Acura Owners do not want to pay 11$ a QT for ATF.
So what ATF has the better Typical Physical Characteristics Test Method Typical Results
Any Info would be very nice.
Thank you
Castrol has.
Honda/Acura
read on.
or
or
Thank you
