Castrol Extend
northern Alabama
Has anyone heard anything about Castrol Extend? The information I saw said:
"Extend and Fight Sludge
Sludge build-up in your engine is one of the worst things that can happen to your car. It can clog oil passages and block essential lubrication of moving engine parts. The longer you drive between oil changes, the greater the danger of damaging sludge build-up.
Introducing New Castrol Extend, the first motor oil that allows you to safely drive 7,500 miles between oil changes and NOT worry about sludge robbing your car of power and acceleration.
Castrol Extend has two unique components:
Greater concentration of dispersants and detergents to keep the oil working in your engine for longer.
Plus Castrol Extend's unique Sludge Fighter technology fights sludge and prevents sludge build-up.
Drive farther and keep your engine running clean and smooth with new Castrol Extend - the Sludge Fighter."
So what do you think the Sludge Fighter component is? Great marketing I might add but should've come out a little sooner when Toyota was having the problems. It didn't say what specs it met or anything like that.
I use Castrol "high mileage" oil in a Merc GM with 140K miles on it. Using standard oil at that mileage meant that I had to add a quart at every fill up. Now I can go 5,000 mi between changes without using any oil. I recommend it to every Ford and Merc high mileage owner that I encounter, and many have come back and commented about solving their oil consumption problems.
I only give that as an example of Castrol products doing what they claim that they will do.
rmw
The same stuff in HDEO oils.
Those high mileage oils are simply higher viscosity oils that use higher viscosity base fluids.
Hi MolaKule. I have 5qts of the SM/GF-4 Castrol GTX 5w30 that can go into the 97 Stratus V6. Would you use it, or choose something different? It's on it's first dose of Mobil 1 5w30. Also, it's only getting colder, nearing 0'F this OCI. Or, if you will tell, what oil do you prefer or use in your engines? Maybe the SM/GF-4 GTX is mostly a group III... Thanks!
