My first extended drain. Not quite sure what to think. Compared to the other samples there are some interesting trends.
Code:
OIL Castrol 5w30 Trop 5w30 NAPA 5w20
Edge Artic Synthetic
Gold Bottle SynBlend
MILES IN USE 9,980 4,989 6,447
MILES 149,085 125,086 114,429
SAMPLE TAKEN 01/14/15 10/23/14 06/01/14
Metals (ppm)
IRON 88 10 45
CHROMIUM 2
LEAD 1
COPPER 4 1 2
TIN
ALUMINUM 19 4 22
NICKEL
SILVER
TITANIUM 20
VANADIUM
Contaminants (ppm)
SILICON 12 8 10
SODIUM 18 17 278
POTASSIUM
Additives (ppm)
MAGNESIUM 278 14 118
CALCIUM 1990 2044 1792
BARIUM
PHOSPHORUS 648 690 627
ZINC 755 761 730
MOLYBDENUM 69 15 6
BORON 58 70 9
Contaminants
WATER (%)
Coolant No No No
Physical Tests
Visc (cSt 100C) 8.9 8.9 9.0
TBN (mgKOH/g) 2.4 2.6 2.5
The relatively high iron (compared to the trop artic) is interesting. but what is more interesting is that on a per 1,000 miles basis the iron level is about the same as it was with the Napa 5w20. Why I find this interesting is that these were both winter time OCI's and the silicon levels are remarkably similar. The trop artic sample was all highway summertime miles with a different brand of air filter and much lower SI.
the aluminum was still quite a bit lower than the NAPA which for this motor could mean less wear on the top end -- which would be quite good.
The TBN is outstanding for that mileage, but this would represent one quart of Edge black, and 2 quarts of Edge gold for top off in the 10k oci.
surprised at the viscosity, though. I would have thought that the Castrol would have held on to the viscosity a little better.
surprised at the copper and lead. but with more miles, maybe those numbers aren't concerning.
What do you guys think about running 10,000 miles on an OCI during the winter?
I'm still new at this so help me out.
Oh, this was with a Bosch D+ oil filter.
Current fill is the same oil for same OCI and Fram Ultra filter.
Code:
Metals (ppm)
IRON 88 10 45
CHROMIUM 2
LEAD 1
COPPER 4 1 2
TIN
ALUMINUM 19 4 22
NICKEL
SILVER
TITANIUM 20
VANADIUM
Contaminants (ppm)
SILICON 12 8 10
SODIUM 18 17 278
POTASSIUM
Additives (ppm)
BARIUM
ZINC 755 761 730
MOLYBDENUM 69 15 6
BORON 58 70 9
Contaminants
WATER (%)
Coolant No No No
Physical Tests
