Blackstone comment:
This is the virgin sample of Castrol Edge 5W/30 you sent in. The main additive in this sample is
calcium, a detergent/dispersant additive. Boron is another detergent/dispersant additive. There are similar levels of phosphorus and zinc (ZDDP), as well as some molybdenum, all of which are anti-wear additives. This oil contains titanium as well. No contamination is present. The TBN is 7.7 and the TAN measured 3.1. The viscosity was in the correct range for 5W/30 as well. This oil is ready to be put into service.
Code:
ALUMINUM 0
CHROMIUM 0
IRON 1
COPPER 0
LEAD 0
TIN 0
MOLYBDENUM 64
NICKEL 0
SILVER 0
TITANIUM 0
POTASSIUM 22
BORON 310
SILICON 4
SODIUM 2
CALCIUM 1950
MAGNESIUM 8
PHOSPHORUS 604
ZINC 737
BARIUM 0
SUS Viscosity @ 210°F 59.1
cSt Viscosity @ 100°C 9.96
Flashpoint in °F 440
Fuel % -
Antifreeze % -
Water % 0
Insolubles % 0
TBN 7.7
TAN 3.1
Pretty sad for me. This is an oil that should be suitable for 15k service interval. But I see that TBN is just 7.7. Detergent additives are not great too, moly and titanium are in homoeopathic dozes. The only bright spot is boron.
Code:
ALUMINUM 0
CHROMIUM 0
IRON 1
COPPER 0
LEAD 0
TIN 0
MOLYBDENUM 64
NICKEL 0
SILVER 0
TITANIUM 0
POTASSIUM 22
BORON 310
SILICON 4
SODIUM 2
CALCIUM 1950
MAGNESIUM 8
PHOSPHORUS 604
ZINC 737
BARIUM 0
Fuel % -
Antifreeze % -
Water % 0
Insolubles % 0
TBN 7.7
TAN 3.1
