I'd say that if the test was run by a reputable lab, then there are real differences between the oils. As I read it, the Sequence IVA test forces 100 hours of cold temperature operation on the engine, simulating years of intermittent stop and go driving, where the engine never warms up. They UOA the oil for Fe and Cu wear and physically measure and average the cam lobe wear.
ASTM and SAE think that this test correlates to wear in real engines. This test will also be included in the GF-5 spec.
Quote:
Development of the Sequence Iva Valve Train Wear Lubricant Test: Part 1
Document Number: 2000-01-1820
Date Published: June 2000
Author(s):
Takamaru Sagawa - Nissan Motor Co.
Kiyotaka Nakamura - Nissan Motor Co.
Larry M. Bendele - Southwest Research Institute
William A. III Buscher - Southwest Research Institute
Abstract:
The ASTM Sequence VE test evaluates lubricant performance for controlling sludge deposits and minimizing overhead camshaft lobe wear. ILSAC asked JAMA to develop a new valve train wear replacement test since the Sequence VE test engine hardware will become obsolete in the year 2000. JAMA submitted the JASO specification M 328-951) KA24E valve train wear test. This first report presents the results of technical studies conducted when JASO M 328-95 was reviewed and the ASTM standardized version of the KA24E test (the Sequence IVA) was proposed.
The cam wear mechanism was studied with the goal of improving reproducibility and repeatability. Engine torque was specified to stabilize the NOx concentration in blow-by, which improved test precision. Additionally, the specifications for induction air humidity and temperature, oil temperature control, and test fuel composition were modified when the ASTM version of the KA24E test was proposed. The KA24E correlation to Sequence VE wear was studied, and good agreement was documented. The correlation between field performance and KA24E engine test results was also investigated. Field tests conducted with two different wear level oils ranked wear similarly to the KA24E engine tests. Based on these studies, the KA24E test was proposed as the ASTM Sequence IVA test method.
Sequence IVA test
