Originally Posted By: buster
Quote:
Another question I have is 'repeatability'. Run the sequence test a dozen times. Will there be times when an oil beats another oil that beat it earlier? Comparing results in a pass/fail test really all that fair?
Hows does Castrol create its time:wear graph? Does the engine get disassembled non-stop throughout the test or just in the end for UOAs and measurements? And, what data are they comparing? Copper or iron UOA measured wear? Or pre/post lobe/bearing/surface wear? Overall average or just our best wear point vs your worst wear point? Ad-budgets rarely need to define themselves. Our lowest measurement wear point is better then your worst wear measurement point!!!!!!!!!
Marketing aside, probably a great oil but not in the weights I need. And its priced where I would rather order a few cases of Amsoil(or any other mail order boutique synthetic).
Bring out the Edge 0w20, 5w20, 0w30, 0w40, 5w40....price it accordingly, and Mobil1 sales will slide.
Yes, they monitor Fe and Cu wear via oil analysis. This is how they track wear vs time.
On price, people often complain about the cost of high end synthetics but if you take advantage of the extended drain intervals, it becomes more cost effective. Amsoil is also a full PAO based oil so cost will be higher. Being Edge is using some PAO, the price is a bit higher than their Syntec. Edge also has a better additive package. You get what you pay for..
I can get a full PAO Amsoil product for even cheaper than what Castrol is asking...
