Castrol 2 Stroke?
Redhorse, no flame intended, but I would use the Pennzoil air cooled 2 cycle mix only in an emergency, if no other 2 cycle mix was available.
Pennzoil Air Cooled 2 Cycle Mix Product Data Sheet
This is an older style formulation, API-TC is a mid 1990's spec, look for a 2 cycle mix that meets the current JASO-FC, ISO-EGD specs for low smoke & low deposit performance.
I use castrol TT-S in our companies Motor Glider. It has a Solo 52 HP watercooled engine. The TTS works very well in the watercooled application.
Keep in mind that the glider engine works very hard, as it is always full throttle.
I like TT-S
Chris
Yes, Castrol does make a 2 cycle oil for mowers, etc. I have bought it in a quart container for years from Pep Boys. I have never had a problem with it. I am not a fan of Castrol to be honest, but this stuff seems to be fine. I used Sears synthetic 2 cycle oil, mixes the same 40:1 ratio in my leaf blowers, one died and lost compression, the one one would overheat. I thought it was trashed, but I tried Castrol in there and it is back to life. No damage done. Sears synthetic 2 cycle oil is GARBAGE in my book. It comes in a gold bottle.
Mike
