Castor Oil for rear main seals?
California
Recently saw a Youtube claiming castor oil could be used to restore leaking rear main seals. It states it cannot fix a leak from a cracked or torn seal. Only a seal that has shrunk to the point it no longer can seal.. It said to add 2 ounces/qt of motor oil. Castor oil seems like a benign additive to use. Even if it didn't work, I don't see how it could do any harm to try. Anybody ever tried this or heard about it?
I completely agree with the people above. Castor oil makes mess inside the engine and its use is justified only in racing applications where people put apart the engine after each race and thorrowly clean its internals.
Also, as far as I know, without any solvents (like gasoline in 2-stroke applications) castor oil won't mix well with other oils, regardless if they are conventional or synthetic. Castor oil cannot be or it's not recommended to be used below 35°F. In low temps. and larger amounts it cannot get in suspension even with gasoline, which is one of the best solvents.
Here I briefly outlined several properties of the castor oil:
https://bobistheoilguy.com/forums/threads/castrol-is-bringing-back-r40-castor-racing-oil.403605/#post-7571928
It was tolerable in racing two strokes because the engine was always apart for one thing or another before the castor could get it totally gummed up.
If you have rear main seal leak, use Valvoline MaxLife (synth blend or full synth) or Valvoline Restore and Protect and will help it.
Also, don't fill up the oil to the max on the dipstick—keep it midway or a bit over the middle.
I used my old oil after cooking bacon. I find it thickens the oil up and helps seal all the leaks. Takes it up a grade. Smells good too.
isn't castor oil rubber safe and doesn't cause swelling? its the main product in sil-glyde.
If there was a lip inside the seal one could put high temp grease inside but a lot of seals don't have that groove.
There are threads here about products specifically designed to swell seals and o-rings. I recall a mechanic or two chimed in and said AT-205 and Blue Devil Oil Stop Leak were recommended. They can be used for differentials as well. They said these are not 100% cure alls, but did work many times.
Blue Devil even makes a version specifically for rear main seals. I'm curious how it differs from the Oil Stop Leak version.
Tried both the AT-205 and Blue Devil RMS sealer on a failing rear main for the wagon. Leak slowed but never completely stopped. What DID stop the leak for about 5K was Valvoline MaxLife in the red jug (synthetic blend). Eventually it started dripping again right up until it finally stopped for good with the replacement of the seal.
I say it is a bad idea and more internet misinformation.
Pure Castor oil contains glycerin, an oxidant that destroyed many an engine before they separated out the glycerin.
I know of no real seal swelling capabilties of raw castor oil.
I used to see young mechanics putting red rubber grease, which is castor based on oil seals. It's ok for rubber they'd say...but oil seals are not rubber ! It will gum up and ruin the seal. Castor oil was used in engines like speedway bikes because they ran on methanol because they will mix, it won't mix will mineral oils easily, it will separate out and gum up.
I saw the same video and it was not just any castor oil, but agricultural grade castor oil. Was supposed to be some ole tyme fix. But I will pass on it.
Hard pass here. Caster oil will not tolerate inside an engine and won't do anything but turn into a deposit inside your engine.
Agree. I remember castor oil being used in racing applications like LeMans and it was a giant NO never to mix a petroleum oil with castor oil because of complete incompatibility. Doing that here.
Here you can read more about castor oil and its properties.
Castrol R40
https://www.classicoilsusa.com/products/castrol-r
Klotz BeNOL
https://www.minicars.se/internt/artiklar/internal_documents/BC171_BC172_BC175_Tech_Sheet.pdf
