I have a Toro walk behind mower and the idle surges and eventually just slows to a stall. I've tried for a day setting the idle via the screw with no sucess.
So I'm thinking the carb is gummed up. Is it bad to spray something like Deep Creep or Gumout directly into the carb and should this be done when it's running or not?
I was also thinking about running some Redline SI-1 through the gas tank on a full mowing to clean it out. At full throttle, it runs fine, although it has a hint of a miss sometimes, but it'll darn near nock over small trees and barely lower the rpm! (5.5 hp OHV).
Thoughts?
Thoughts?
