Car wash mitts/sponges
JHZR2
Staff member
New Jersey
What is everyone using?
I've gone from chenille mitts, to spongy type mitts, to grout sponges, to ???
I've seen some say to use lambs wool. I never have.
Recommendations?
I've never swirled a car with my wash approach and care for mitts/sponges, but I want to be a little more careful on soft Honda paint.
Thanks!!
I use a microfiber mitt from harbor freight. Before that I had a chenille mitt which now gets used on the wheels.
I'm very happy with the quality of the harbor freight mitt. It's very dense.
Before using the mitt, I use a pressure washer to first rinse and then foam. The microfiber mitt gets regularly dunked and scrubbed into a large rinse bucket with a grit guard.
I use the dark grey "wool" mit that O'Reilly Auto Parts sells. Works pretty good. I don't like the microfiber mits because they don't seem to scrub the gunk off very easily when you need them too.
I've hadicrofiber ones before. I've liked the sponges, but the mitts never had the population of microfiber high enough to avoid the rough substrate from touching the painted surface.
Been using lambs wool mitts since as far back as I remember.
On black?? Source?
The guy on the Ammo NYC detail videos on YouTube seems to like lambs wool.
JHZR2 -
Couple of options...depending on budget.
The Chenille *locks* microfiber mitt at most autojoints is fine for the lower panels - that's what I use for all lowers. It's safe/soft enough for the top - if you're not that picky...
Sheepskin mitt is pretty good....u just need to wade through the stack and pick them like fruit, get the largest, fluffiest ones.
If you don't have a pressure washer, consider it.
It is IMO the biggest tool, even as a pre-rinse, to knock as many micro-contaminents off even before you take your wash media to paint.
I've got foam-guns, but IME, it does not do that much to mitigate wash issues.
IMO, MOST of you marring will comes from drying, not washing.
Use a garden blower...and get most of the water off that way and then blot the remaining water.
Hope this helps
On black?? Source?
Sorry, I goofed initially. Sheepskin is what I use, like this one:
http://www.autogeek.net/sheepwas.html
On black?? Source?
those aren't rated all that great, have you been happy with them?
I used the grout sponges for Lowes from years. They were made in Greece, then they switched brands and the new ones were not soft like the old ones. I now use the Lake Country sponge.
I used mitts with a cut pattern like that before I went to grout sponges. I use the German made ones from Home Depot currently.
I like the microfiber chenille wash mitts but there may be something better. They last a good while for me and do a good job of cleaning. I use a grit guard in my bucket with meguiars gold class shampoo.
