I belie I clearly said I wasn't concerned and it wasn't a problem merely I was making the case that considering the drive and conditions it's subject to maybe changing it before 7500 and closer to 5,000 is a decent idea? I In no way think there's an issue it's completely normal. I just thought it showed the oil probably sheared some and would explain the usage at around 5,000 miles.
Or maybe it didn't. You could do a UOA and find out, but your engine is still breaking in right? If so, varying levels of consumption may be perfectly normal. I'd run the OLM and see if the same thing happens next time.
It's got almost 10,000 miles on it do you think it's still breaking in?
I'm sure parts of it still are, yeah. This is what, the 2nd OCI since new? Check the filter when you change it, if you still find break in metal, that answers your question
There was a fair bit that came out of my 6.4L on the 1st OCI and I'm sure I'll find some more the 2nd time around.
