Originally Posted By: TFB1
Originally Posted By: HTSS_TR
How do you dump oil out the filter ? ADBV supposes to prevent oil in the filter coming out. I put an old oil filter upside down for a week and still have plenty of oil in it.
Ummm large threaded hole that mounts the the filter to block and gravity, that will do it... Left upside down for a couple hours probably 90% or more of the oil will be drained... All it has to do is wick through the element and out the mounting hole, this ain't rocket science...
Now I'll reveal how I have not changed the filter but flushed it... Drain oil, reinstall drain plug finger tight, dump in one quart, start engine and run for 10-15 seconds, remove plug(cut the engine off), drain oil that was flushed from filter... This works, but engine MUST be HOT... The key is not run the engine long enough that the oil flushed from the filter circulates back into the engine... Also if it's a small filter you're actually wasting oil, the V8 Fords have a large enough filter that little is wasted...
No this isn't a recommended procedure to all BITOG...
Bad idea, only one quart? The engine will suck the pan dry when it fires.
