Originally Posted By: haynal
Come on where are all the Hot Rod Gear Heads??
Struggling to understand your spelling...
In all seriousness, a knock is rod bearing...a tick is a lifter...so, which is it?
A knock is deep within the engine, and it sounds heavy...that's what you've described.
You say that it can't break sitting there...and yet it's broken...so what response do you expect? If it's really a knock, then you have a serious problem. Could be that when it was last run, you spun a bearing, only it didn't make a sound because there was no load on the engine...and now that it's been unused, that bearing clearance won't let you develop oil pressure and the knocking is not going away...
If it were mine, I would pull the oil pan and check each bearing. If you're lucky, you'll find the bad bearing and be able to replace it. If you're unlucky, it's going to have to have the crank turned to get rid of the scoring on the journal...
While Zinc may be important, most HDEOs have as much Zinc as the Brad Penn. Zinc, by the way, is a component of ZDDP, which is what you're really after. A good HDEO or synthetic would be my first choice for your engine...particularly if you're going to start it in the winter time...even in 1932, a 40 wt was not recommended for winter use...a multigrade would suit you better...and the best multigrades are synthetic.
Before you dismiss the synthetic suggestion - consider that your engine has just had an oil failure/problem...you've lost a bearing...so your current oil selection CLEARLY doesn't work...
