Okay AKhan. You are correct. The Walmart nearest me does not have an auto service center. But, I will heed you're advice and discharge battery. They do scan it, so maybe there's something in that scan tool that reads something...They scan it it across the top of the battery, where the cell caps are... I dunno. I will play it safe. Discharge battery. I don't want the Walmart Greeter lockin me up
Thanks for the info.
Today, I helped warranty a EverStart Max 124R battery for a friend as he had no idea how the whole process worked, especially since he had not kept his receipt, the battery died after two years of abuse (I think his vehicle has a parasitic draw but I didn't confirm as I was just testing his battery before we took it to Walmart)
Below is the test on the dead 124R battery - it was approximately at 75-80% battery fluid level
I cleaned the battery and then removed the cell covers, and topped of the fluid with distilled water to get the level to ~100%
After 5 cycles of the "12V repair" function on my NOCO Genius 10 - below is the test result on the same battery
If I had a welder, this would could easily be revived but I don't have an outlet capable of handling a welder where I am currently living.
Took it to Walmart because I knew the battery was bad, and they ran it through the complete 90 minute cycle because they had to (according to them), during charging they said the battery was good and I had to wait another 30 minutes, and after the completion of the charge cycle, it had failed the load test...
They warrantied the battery using the serial number, and gave a receipt which showed that the warrantied battery has 1 year remaining on the warranty.
Note: I tested 3 new 124R batteries before picking the one with the lowest internal resistance (target: 4.00 or lower) and highest CCAs.
I will do the following before the NEW battery is installed on the car:
1) Fully Charge it
2) Top off battery fluid with distilled water (all the new Flooded Lead Acid batteries (30+) that I have seen in the last 2 years are low on fluid even when new)
3) Fully Charge it again if needed, some batteries took a while to be fully charged after being topped off.
4) then it will be installed on the vehicle (I hope my friend is able to diagnose the parasitic draw before he installs the battery)
by doing the above, they battery will EASILY outlast the warranty period (unless the vehicle just sits or has a parasitic draw), I get around ~7 years of battery life on Flooded Lead Acid batteries, and all my cars now are AGM as they test 200-350+ CCA then listed when new and even after 2-3 years of use.
Well, for what's it's worth, I use Walmart because it's the closest to my home....,,,,and way cheaper than Auto Parts Stores... Heck, there's no Costco near me at all, or a Home Depot. So, I'm kinda stuck with Walmart. Still, that's no basis for you're decision.
My 1st choice would be Walmart due to having stores all over the country for warranty if needed and also their cost is the lowest I can find, unless Sam's Club has some sort of promotion.
