JHZR2
Staff member
Hi,
I have a mac mini, a 160GB WD USB2.0 external hard disk, and a 2.0GB CF card from my Nikon digital SLR.
The WD drive is formatted from the factory as FAT32 (which is what I plan to keep it as, since It will be used with both a mac and PC), and I assume the CF card is formatted as fat32 by the camera.
I have a number of directories on the CF card that I want to transfer to the HD. Both the HD and CF card reader are plugged into a USB2.0 hub, connected to the mac. all devices on that USB port are 2.0 compatible.
If I drag one folder at a time, they seem to transfer OK. If I drag multiple folders that only take up less than 100 MB each and copy multiple at once, they seem to work OK.
If I drag my main 'DCIM' folder, which has the latest photos from my camera (about 1.24 GB) to the HD, if anything else s copying, it just stops midway in copying and does not continue. THe only solution is to hot remove the devices from the hub, or reboot the computer.
If I select more than one folder and copy them at one time, the thing wont copy, itll get stuck midway.
So,
-ny ideas why Im having problems copying files from one drive to another on the same USB hub?
-Is there a way to 'cut' and paste the files from one drive to the other, rather than having to sopy them from one to the other and then delete them from the original drive? In mac, of course... its easy to do in Win2k
-Any suggestions how to better enhance my file transfer speed and prevent issues like what happened from happening? I transfer large files from various drives quite often.
I really dont want to have to boot up my PC every time I want to transfer files from my memory card to my external HD.
Thanks!
JMH
So,
Thanks!
JMH
