I don't think your truck is totaled, but yes you can easily total a vehicle with a flat tire, I saw it many times working in insurance.
Only on a school bus.When a front steer tire (have to be new by DOT requirements) on a semi blows
I have a full size spare, it’s on and the rim is at a shop here in Breckenridge waiting for a tire. No trails until I have a spare backLots of tread left on that tire. Did you keep going or go home? Find a new spare?
Not all tire failures like this are retreads. In fact most are newer tires. I doubt the OP is running retreads on his nice truck.Major tread separation. Was it a re-tread?
Please tell more about the tire that failed?
How much weight was in the bed of that truck when it blew?
I agree, something may have hit the fire causing it to explode like that.….
I would not be surprised if a piece of debris in the road was the root cause of this. The way the tire exploded, you may not be able to tell, but I suspect it wasn’t material failure the tire, but rather a piece of debris kicked up by the right front that happened to catch the rear at just the right angle.
Hmm, never thought about that when I'm trying to hypermile with the Prius behind a truck /
I guess that came to an end now /
I always pass them as fast as I can, especially with the Corvette. Don't want to dawdle in his mirror blind spot. If I cannot see the driver's head in his mirror, he cannot see me.I was on another board that had a couple pro truck drivers on it. There suggestion was when passing a semi - do it as fast as you can. You don't want to be anywhere near them if a tire blows - and they blow all the time.
