- Joined
- Nov 29, 2009
- Messages
- 9,514
Does it hurt anything?
Ohthe drier is in a closed circuit, it removes water from the refrigerant. Or I misunderstand what you mean.
I usually turn off the hvac when the windows are down, but you could run with ac windows up or down
When you think you look “special” in your expensive convertible with the top down….Can I ask why you would want to ?
Because it's too hot to have the windows down, but the cool 50 degree out coming out the vents makes it bearable in stop and go traffic.When you think you look “special” in your expensive convertible with the top down….
and it’s a warm day. Top down / AC on MAX!
Will void most new car warranties.Does it hurt anything?
You've actually seen a clause in car warranties that voids the warranty if the a/c is ran with the windows down?Will void most new car warranties.
Hey it is what I do in the WS6. I am ok with it. Tops off, AC on, 11 Second quarter miles. Bald Eagles and stuff even though it was made in Canada Eh!When you think you look “special” in your expensive convertible with the top down….
I often do this... for a few miles, while waiting for the duct work to cool off and to get cold air coming out.
But otherwise, windows go up and recirculate goes on. Then the a/c (which is burning gas, above and beyond what is needed to move the car) can do its job. Yeah you can drive around, windows down and a/c on, but it's kinda just a waste of gas.
Now driving with windows down and heat on (spring/fall or even winter), no cost, most engines have plenty of heat to spare. Although in an EV that might be the worst thing to do!
If it's too hot to have the windows down, then why do you have them down? I'm not following...Because it's too hot to have the windows down, but the cool 50 degree out coming out the vents makes it bearable in stop and go traffic.
You realize there's a temperature knob ? You can run the AC set to "hot" if you want.but the cool 50 degree out coming out the vents makes it bearable in stop and go traffic.
