Can you hook up an equalizer to Onkyo TX-SR353?
los angeles
Here is a rear image. I looked up how to, but all I get is "hook up to Tape in-out". Thanks.
How do you get the audio input in? The equalizer would normally between the source and the amplifier. I'm guessing it's through HDMI. I'm sure such devices exist
You want an "HDMI audio extractor", which will give you analog audio output from an HDMI source.
I guess we should take a step back and ask OP what his source signal is. If it is a device that has HDMI output, such a TV or DVD player or some media streamer, then yes, an HDMI audio extractor can convert audio to analog, but then he'll lose the whole 5.1 DD/DD+ aspect of it. And what about the video part of it? How will it all come back into the AVR?
Now, if his source signal is just 2-channel analog audio (RCA), then sure, he can just run that source into his equalizer and then send it to the AVR using the AVR's analog audio inputs.
Sounds like a lot of work for little gain unless you enjoy tinkering with this stuff, which I used to, my first surround sound was all separate components.
My Yamaha uses YPAO similar to the OP's AccuEQ, here is some verbiage from my manual which explains how it works in case one is interested. You need to place the mic near your seating position or in the center if you have multiple seating positions.
Yamaha's YPAO system uses a small microphone and sophisticated equalization to automatically set the best sound for any room, no matter where the speakers are. First it checks the speaker connections and phase of each speaker. Then it sends out tones which are captured by the microphone to analyze the room acoustics and sets a variety of parameters, such as the speaker size, the distance of the speakers and even the sound pressure level, until it achieves the best sound conditions for your room.
The main thing that I want it for, is to listen to music from my phone, from Pandora. Did this stereo also come with that microfone adjuster?
Get a bluetooth receiver and connect it to the CD input on the box? Assuming your phone doesn't have a headphone socket, in which case you could use a 3.5" to RCA cable....
Like brian703 stated, if your phone has a headphone jack, then just run a 3.5mm to 2xRCA cable from the phone to your equalizer and then another 2xRCA cable from equalizer to the CD input on your AVR.
Alternatively, since your AVR has Bluetooth built-in, you can wirelessly stream content from your phone to your AVR. You will not be using your equalizer in this case.
It did.
Back in the day, an EQ was inserted through the “tape loop.” It was fed via “tape out” and the “tape mon (monitor) button was always left engaged. If you actually wanted to listen to tapes, you chained the tape deck off the EQ and it had a tape selector to switch over to. A smaller group of units had EQ send/return connections.
of course, nobody knew how to actually do with an EQ what they’re supposed to do, which is notch out troublesome frequencies. Most folks make them look like a smile. For room tuning, it’s got to be a 1/3 octave unit before becoming truly helpful. Also, graphic EQs tend to be noisy…. A parametric EQ with about 3 channels is generally a solid way to go.
Good performing equipment should not need an EQ.
In majority of cases it's the room acoustics that throws frequency response out of whack, even with the best equipment. Proper EQ can help with this, assuming you have a way to measure the response. This usually means using digital EQ (DSP) instead of old school analog one which is just not granular enough to be useful.
