Can this be used with a two piston caliper?
CA
Hi
Can this brake caliper compression tool be used with a two piston caliper, application is a front caliper?
https://a.co/d/0i0VUh3r
I understand that the pistons need to be pushed in together at the same time so one doesn't pop out. I was planning to use one of th eold brake pads and place it over the pistons and use the above tool to press the pistons simultaneously.
Is this a good approach or is there a better way?
Yes, if it doesn't fully cover both pistons, just put the old brake pad in there and push against that. That's what I do.
Kind of like this: (Just imagine two pistons instead of one)
I sure like the look of their "heavy duty" unit over the standard. I might pony up for that -- it's still just $16
