Kind of a complicated question actually.
At sea level there is 14.7 psi pushing on everything. If you can create an area with less than 14.7 psi, liquid will flow there.
A pump that creates a perfect vacuum can lift water approx. 32.2ft. Since oil is lighter than water, (SG=0.86, approx) you could lift it approx. 37.5 ft.
Does that help at all? What are you trying to do exactly?
