- Joined
- Nov 29, 2009
- Messages
- 9,513
I'm at 241,000 miles and 12,000hrs on my 6.7 cummins. Original cp3 injection pump and fuel injectors. Still runs good, but I'm curious as to how long I can expect out if them?
Mine is mostly city driving. I usually go by hours and not miles for maintenance. By the time I get 6 or 7,000 miles I'll be around 4-500hrs on the oil change., which is too long imo.With the 6.7L I have seen highway trucks as high as about 400,000 miles, and I've seen them dead at 100k in a city truck.
The 6.7 is pretty sensitive to injector return bypass, typically your first sign they are starting to fail is hot re-start long crank issues, sometimes accompanied by low rail pressure codes.
Well, you have to stop driving it when you see it start blowing smoke or getttinga bad misfire. Most people keep going, then you need a whole engine rebuildJCB 419 wheel loader with same engine recommend to change injectors at 10k hrs. My personal opinion on that... waste of money
yes, that's correct. Engine bearly smokes. Also the 10k hrs service is over 11k €Well, you have to stop driving it when you see it start blowing smoke or getttinga bad misfire. Most people keep going, then you need a whole engine rebuild
Then again the dpf hides any smoke the engine would produce, so that theory goes out the windowyes, that's correct. Engine bearly smokes. Also the 10k hrs service is over 11k €
What dpf?Then again the dpf hides any smoke the engine would produce, so that theory goes out the window
Yes. Your 6.7 powerstroke is common rail and spits the fuel out at like 33,000psi at full throttle. I used stanadyne lubricity formula for years, but started questioning if it was still good because they haven't done an updated study since 2007. Most diesel fuel has bio diesel in now, or claims it does, so I don't bother with lubricity additives nowI will bet fuel quality and a good lubricity additive along with proper fuel filter maintenance with OEM or quality filters.
I am no expert on injector design but I am guessing the injectors in my PSD 6.7 have smaller holes for the fuel to spray out of that the ones on my older Kubota diesel tractor with a mechanical fuel pump.
I would use hot shot EDT or opti lube.Yes. Your 6.7 powerstroke is common rail and spits the fuel out at like 33,000psi at full throttle. I used stanadyne lubricity formula for years, but started questioning if it was still good because they haven't done an updated study since 2007. Most diesel fuel has bio diesel in now, or claims it does, so I don't bother with lubricity additives now
