General question about factory tpms sensors valve stems and using metal valve stem caps.
While I was at a local mom and pop tire shop getting the tires swapped over this past spring (yes this has been on my mind!) and at the time I just installed "premium" metal/chrome valve caps with the sealing o ring.
After the tire swap, I noticed the 4 brand new valve caps are "missing" and owner is telling me the metal caps corrode the threads of the metal tpms sensor, and then will ruin the threads and they have to cut the sensor off the rim and replace it... Is there any truth to this? I manually check the air in the tires often - every few weeks so all the caps get removed multiple times a year.. Also if that is the case with corrosion, would it be a okay idea to put a very light layer of A/S on the threads of valve stem?
Thanks.![Zany face :zany_face: 🤪](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f92a.png)
Thanks.
