S SHOZ Joined Jun 28, 2003 Messages 9,421 Location Illinois May 17, 2024 #21 I have before. But I run it through a coffee filter first. Takes a day to do depending on how attentive you are.
A atikovi Thread starter Joined Apr 27, 2010 Messages 19,530 Location Suburban Washington DC May 17, 2024 #22 Mewbs said: Where did you buy the fluid from? 12 dollars sounds too good to be true. Click to expand... Honda dealer. I get 30% off.
SC Maintenance Joined Jun 8, 2022 Messages 17,281 Location Lowcountry South Carolina May 17, 2024 #24 atikovi said: I was wondering if it was worth reusing AFTER I clean out the pan. Click to expand... I guess I am the only one that cleans out there drain pan after each use.
A atikovi Thread starter Joined Apr 27, 2010 Messages 19,530 Location Suburban Washington DC May 17, 2024 #25 SC Maintenance said: I guess I am the only one that cleans out there drain pan after each use. Click to expand... Unless you reuse the fluid, why?
SC Maintenance Joined Jun 8, 2022 Messages 17,281 Location Lowcountry South Carolina May 17, 2024 #26 atikovi said: Unless you reuse the fluid, why? Click to expand... My dad always did it that way. Use the drain pan, clean the drain pan, put away the drain pan. Probably because he re-used fluids at some point?
