My CV axles and seals are new... however, 2 days ago the right side axle is leaking on the inner. The mechanic said that if the seals are good, it can be poorly built/rebuilt cv axle.. can a poorly built CV axle cause transmission leaks?
I would first suspect the seal. Any defect or tear during installation will likely cause a leak. Were the seals installed dry? Are the seals missing their garter spring? A good inspection of the seals will reveal the cause of the leak.
With an otherwise good seal, the axle can cause a leak with any of the following conditions:
- axle shaft is undersized
- axle shaft is oval
- axle shaft ground surface is poor or has improper lead-in
