After Shut Down?
My car stays right around 200 Degrees operating temp, if the Temp gauge is to be believed. It gets Hotter when the Engine is off, or "Hot Soak." Sometimes i turn it on and it will be 230 Degrees..
I wonder if this Boiling Coolant ( have mostly Water in there) after Shut Down can pop a Head Gasket.
So far, it has held up. It does not "Overheat"" the issue is the boiling point of Water, and the Expansion Tank has a leak, so it boils there.
