Camry Hybrid questions
USA
1) it's not an AR-series engine. It is a A25A-FXS (Dynamic force)
2) use the 0w-16. The owner's manual says if it's not available, you can use 0w20 as a substitute and change back to 0w16 at the next oil change.
Why? the A25A has a variable discharge oil pump that is also ECU controlled. The ECU controller is programmed around 0w16.
What oil to use? Well, the Toyota 0w16 is quite stout with tons of Moly in it with a healthy dose of Boron.
Thanks for the lucid explanation about the need for 0w16. I wasn't aware of the reason why. I have the same engine in my Venza. I'd like to go with Toyota 0w16, but l just couldn't pass up Mobil-1 for $22/5qt so that's what l will be using.
Southeast
We had the Ford version of this tech (licensed from toyota) in 2008. Even “in a Ford,“ it was remarkable. Highly reliable. And we never noticed any battery degradation over our years of ownership. We knew several Prius owners approaching 200k, and despite the public clamor back then, they didn’t experience the battery woes that the internet advertised. drive and enjoy!!
Sweetie's Prius is about 15 years old ... not a speck of trouble with the hybrid system. I think the Prius and the Camry are quite similar wrt the hybrid system.
