Originally Posted By: JohnBrowning
First any metal stuck to the magnet is not going to be a problem it is not like those are electromagnets and the metal is going to release back into the oil at shut down. Once it is on the magnetic it is their forever. Second no metalic particles like clutch pack meterial are caught in a type of slush pan. Filter not being changed was a major source of transmission failures for them out of warranty wich was hurting reputation so they did away with them. Their are some mesh filters deep in the transmission to keep anything bigout of the accumulators and such but you have to get deep into the transmission to get at those. This is why I always tell people to change their darn fluid every 15,000 miles. I mean we are talking about less then 4 quarts of fluid every 15,000 miles. If you are going to keep the car 5,6,7,13 earsw it makes sense to do this so that the transmission lasts as long as the engine does. If not then some place between 120,000 and 200,000 miles you are droping $1500 for a rebuilt trans and labor to install it etc..... or $500 for one out of junk yard and $300-$500 for labor to instal it etc......Seeing how they give you a convient drain plug just change it! I am not refering to you but most of the people on this site are such cheap gluteius maximus's in that they will spend $30,000 or more on a vechile, then spend $7-$16 a quart for motor oil and $4-$20 for an oil filter but complain about changeing their transmission fluid at 15,000 miles.
If the vechile use's T-IV then it can also use Dex-III or better with no ill effects so cost need not be a factor. It is not like you have to drop the pan or anything elaborate. I just do not see what all the fus is about.
Absolutely. 15,000km drain and fills for me. Got T-IV today for cheaper than the cheapest generic ATF. $32 for 4L for T-IV from the dealer, and at the shops the generic stuff goes for $35 or more.
Now the dealer didn't have any ATF sump plug washers, can you believe it?? And also I couldn't find single torx T55 bits anywhere, they always come in a crummy set of 10 sizes but I only need the one
