I used to do all my cars/vans ATF changes by draining out the old, refilling and then using the cooler lines did a quickie start/stop of the engine to get more of the old out of the torque converter until it turned mostly new looking. I was in danger of cavitation of the ATF pump (a very bad thing) each time I did this. I have also always installed either an external trans cooler or the Magnefine trans in-line filter so getting access to the lines was not really that much of a problem.
I stopped doing this and have instead moved to the drain/fill method (which is the OEM method for my latest car anyway). I just did it twice after driving many miles on the 1st drain/fill. Now I have decent confidence that I have much cleaner/newer ATF without totally "shocking" the tranny with totally new fluid. ATF is pretty cheap anyway since I DIY'd it (using 12 quarts of Amsoil OE Synthetic ATF on my Optima).
FWIW: The total capacity of my tranny is 8.24 Quarts (US). You can only drain/fill ~6 quarts at a time (OEM service method).
I'm sure other vehicles will benefit from this and other methods discussed as well.
