Cam wiped out - MaxLife 10-40 blamed
Originally Posted By: Max_Wander
What I do appreciate is the engineer's kindness of an over-built production engine.
Well Max, then you should positively ADORE engines like the Ford 460, Mopar 440, and Olds 350. They just don't come any more "over-engineered" than those old brutes.
The fact that properly breaking in a flat-tappet cam is essential is no different than the "special procedures" (iow, no big deal) for torquing an aluminum head on an open-deck aluminum block in an import engine. Once that cam is broken in, those old engines will run FOR EVER. Even with pretty poor treatment. I once drove a happily purring Mopar 383 in my garage for a valve cover gasket change, and discovered that 3 cylinder head bolts were loose (and don't blame the factory, a shop had done some work on it about 5 years before and screwed up). Neither head gasket was hurt because the heads and block are so d*mn stout, I just torqued them down again and it ran on for many more years.
As I said in another post, I'll wager that the 460 cam or the lifter in the other forum was flawed. Otherwise more than one lobe would have been wiped. As the demand for flat tappet cams has gone down, I think the quality has really plummeted as well. It only takes one tiny flaw in the surface hardening of a flat tappet cam or lifter to grow into an area that lets the wear pattern quickly chew into the softer steel below the surface. Cam makers are out-sourcing more and more, and now its coming back to bite them. It will happen with rollers, too. Bet on it. :-(
Quote:
Perhaps I can't pin this one on FORD (although I don't find cam in block designs to lubricate as well as a OHC where each lobe gets dipped in oil on each revolution)
"Dipped" in oil is nothing. Most hydraulic lifter cam-in-block engines have a full pressure feed to each lifter bore, usually by each lifter bore broaching into the main left or right oil gallery. Each lifter has a circumferential oil groove that lubes the entire lifter/bore interface, and the oil is then sprayed out of the lifter/bore clearance directly onto the cam lobe face as it rotates under the lifter. On top of that (at least in Mopars) all the oil that returns from the overhead is channeled onto the cam as it collects in the lifter valley on the way back to the sump. Finally, many new-style lifters additionally have a centered high-pressure feed hole right in the middle of the contact face. There's FAR more cam lubrication there than on most OHC designs I've seen.
I'm not anti-OHC (I currently own one and just sold another with nearly 260,000 trouble-free miles), but cam-in-block still has a lot of advantages. Otherwise engines like the GM LS series (seen the specs on a Z06 or ZR1 latel?!?) and the modern Mopar Hemi wouldn't turn in the numbers like they do. And its not just raw horsepower- you have to fight REALLY hard (see Northstar :-/) to package an OHC engine of a given power in the same size package as a pushrod engine of the same power.
Originally Posted By: lazaro
just under 200lbs seat pressure?
are you sure the seat pressure is that high?
[/quote]
It may be more than "a bit" under 200, but I'd honestly have to go back and look at the machine shop's printout. 140 sounds too low, but I do have CRS disease lately.
At any rate, its higher than the typical "low po" Mopar cam, but its basically a tad higher than the factory used on Magnum engines back in the 60s with a bit of shimming as needed to make all the installed pressures uniform.
hmmm.
I never let any machine shop assemble heads for me.
lots of information on the subject to steer you in the right direction.
I am one of those mechanics that takes his sweet time to put things together.
Valvetrain is the easiest place to make or lose alot of power
It's been a lot of years since I installed a cam. IIRC we would marinate the cam, and cam bearings with STP, then pour STP on top of the cam once it was installed. No cam related problems, but this was back in the 70's. I'll have to ask my brother and see if he mixed the STP with a small amount of engine oil or not.
What I do appreciate is the engineer's kindness of an over-built production engine. A little known Japanese IRON block, for example, with high flowing DOHC, 4 valve/cyl head on an engine that didnt come turbo from the factory, will STILL make 550+whp reliably entirely stock (and still uses flat bucket lifters). Never ever heard of cam problems.
In which case, the Ford Duratec (4V DOHC) would be your cup of tea. They last practically forever in daily drivers all over the country, are very easy on oil, don't have cam problems, and are extremely stout as proven by Noble. I've seen Nobles lay down in excess of 500 rwhp with relatively low boost 3.0L Duratecs.
The 3.5L Cyclone "Duratec" is even better on all counts.
I'm a big fan of the engine that the Duratec V6 is based on; the Mazda KL! The KL in fact had a lot of input from Porche engineers. There was a LOT of research put into the KL, I think the SAE papers are still flying around on the net. Split, high ridgidity Al block, massive main and rod journals, forged crank and rods, very high flow heads, coned block shape, iron liners, cast, iron main bearing brace cast into block, helmholtz resonator intake manifold, cloverleaf chambers/pistons, etc.... this engine was basically the best new compact Aluminum 60degree V6 to emerge from Japan at the time, followed by the Toyota MZ(funny code, a tribute?), the Honda J and the Nissan VQ. Once the KL was done, Ford instantly 'borrowed' a lot of the engineering from both Mazda and Porsche and watered it down for the Duratec 2.5L V6 (smaller journals, changed the bore and stroke eversoslightly, so that it wouldnt be an EXACT copy), and there you have it. The KL was so far ahead of it's time, when Ford had not one DOHC V6. I'm not sure if they even had an Aluminum engine in 1990... later on Ford kinda said "yeah, thanks for the work, we'll pick up on the Al V6's, now we want you to just engineer an Al 4cyl for us" which manifested as the L-engine (MZR, Duratec I4). Just for anyone curious, the aluminum L-engine (MZR/Duratec I4) is an evolution of the Mazda F-engine. The 2.2 F2 and the 2.3L L3 in fact share the same 94mm stroke, same 158mm rods (and thus the best in class rod ratio of 1.68:1 on 2.2+ class 4-cylinders out there now, only the Toyota 2AZ comes close). Between the F- and L- engines the standard bore size was increased 1.5mm from 86mm to 87.5mm. Therfore the old 2.2 geometry now displaces 2.3L, and the 2.0L FE which was a square 86x86 was changed to shorter 83mm stroke to preserve the 2.0L displacement with the new standard 87.5mm bore. The old FE and next gen LF engine both have awesome 1.75:1 rod ratios. The F engine is one of my favourite 4cyls. When I mentioned the 2.0 Japanese iron block from 1986 that can take 550+WHP (commonly more) with matching torque on stock parts, it was the Mazda FE-DOHC I was talking about :) I've yet to see a stock rod break, theyre forged & HUGE (nearly twice the size of SR20DET rod). Ford also used the F blocks (in the probe/telstar/courier/ranger international) since the mid 80s. Glad to see the engineers knew a good thing and just updated it. I got worried when Mazda went to the 2.0L FS (Protege engine) as the base engine, the FS isnt a real F engine, it's more of an overgrown BP, glad it's gone! Put short, the L engine is really just an updated F engine with VVT, Al block, reverse flow head, timing chain, balance shaft, and DI. Which brings me to the point that a lot of Ford's successes now are blatently based on their affiliates work (Fusion, Edge, Duratec engines, DI technology, chassis sharing etc), and they have definatly cashed in on the little known engineering powerhouses like Mazda. Ford of America in this day seems like more of an engineering brokerage firm to me, Ford of Europe does most of the Ford engineering, you know except for the trucks and the modulars.
1964, all-aluminum short-stroke big-bore DOHC V8.
Ford has been at this a LONG time.
They have benefited greatly from their Mazda partnership for sure, but one should not intentionally omit Ford's own engineering accomplishments to make it appear as though everything has been borrowed from Mazda. It has not.
^ thats wild, nan. Whats the engine code for this?? I'd like to look it up... Those rods look beefy!
Well I meant that as the current status of Ford of America. They get a lot of 'help' from Volvo, Mazda, Yamaha, Cosworth, PSA group etc... it all benefits Ford and their shareholders, which is fine. It's one of the main reasons why they're in the best position of all american automakers right now. Engineering sharing is the future of global trade and practically every automaker is doing it now. Ford currently stocks enough relevent engineering to carry them over for a while, esp. the base for their "EcoBoost" initiative which is said to replace a lot of their larger powerplants and secures them a way to beat future CAFE requirements..technically in controlled EPA cycles... in reality theyre probably better off with the larger disp. natural aspirated engines.
And an article on Ford's race involvement during that era:
http://www.motortrend.com/classic/features/c12_0612_ford_racing/index.html
The 3.5L Duratec shares nothing with the 3.0L Duratec, and is a superior engine in almost every respect.
You're right, there are no parts shared among the two generations of Duratec. The Cyclone is just an evolution of the original Duratec V6, mostly to allow larger displacement configurations than was possible with older block with added provisions for Turbo and DI. It is a nice engine. If I owned one, the first thing I'd do is equal length primaries exhaust headers so that it sounds as refined as it runs
Max,
Having had a few of both the Mazda V6 and the Ford Duratec apart, I fail to see the "strong similarities" you mention. Mechanics gained a very strong love/hate relationship with the Mazda design as they didn't fail often, but when they did they were miserable to work on. Mazda used a timing belt, Ford used chains. Mazda's warped in unusual places leading to sealing issues. Mazda's seemed to love to blow the spark plug well seals and the labor to replace them was difficult and time consuming. The resulting repairs including replacing spark plugs and wires. The valve trains are so completely different that they looked like they were from two different worlds.
A much closer relationship can be drawn to the Mark VIII 4.6 V8 (and later Cobra and eventually Navigator, Aviator, Marauder, GT, Shelby etc). It is a 60 degree version V6 version. It is part of the Ford "modular" family. It shares the same valve train configuration.
It would be best to clear up the Porsche involvement with the Duratec engine. The involvement was limited to Porsche Engineering, a division of Porsche that does contract engineering for whoever will hire them, similar to Goodrich in the Aerospace segment. Ford hired them for a short time on the Duratec project while they were low on engineering resources. It is not a Porsche design. Porsche Automobile had no involvement. I'm pretty sure that Porsche Automobile wouldn't claim that design.
As far as the Mark VIII engine that the Duratec is a derivative of, Ford engineers I have talked to said that "Ford learned a lot from Yamaha" although I don't see much more than the DOHC 4V portion of the configuration with the Taurus SHO engine. I believe that it was entirely a Ford design, with Ford benchmarking other similar designs.
I think Ford would like to forget any relationship with the Mazda V6.
Originally Posted By: Big Jim
Max,
I've never ever seen a KL "warp" in any unusual place. Theyre incredibly tolerant to heat, the only way they blow head gaskets is if they overheat- bad. Even still, the use of a coated multilayer stainless steel head gasket allows a greater deal of deviation before a failure to seal occured. But aside from that, the KL design is much more durable than te Duratec 2.5. I'm not sure if a Duratec 25 can push 11,000RPMs stock with only valvesprings and external oil pump (stock pump grenades after 8K+). Or 1200+whp on stock block, crank and head castings. Not saying it's impossible, just havent seen that. There are also a couple diff valvetrain designs used on the Duratec 25, some with DAMBs and some with roller fingers. The K-series only came with DAMBs (HLAs and solid buckets).
Quote:
A USA oil company researched engine longevity using their own oil:
"After 300,950 miles the Mazda MX6-V6 passed an IM 240 Exhaust Emission Test in Aurora, Colorado, with results well within new car limits. At more than 310,000 miles, the test engine was disassembled for inspection and measurement. No wear was evident on valve stems and guides, main and rod bearings, crankshaft main and rod journals, or cylinder walls. The cylinder hone marks from original factory machining were all clearly evident. While piston skirts showed no wear, piston rings showed an average of only 0.0015" of face wear."
The V6 rivals the Lexus V8 for longevity, which is unsurprising considering the original application was a Xedos6-2.0V6, Xedos9-2.25/2.5V6 & Sentia rotary luxury lines. Many V6s & I4s have exceeded 350,000 miles, the only failures on one was a Mitsubishi alternator at over 200,000 miles and the pre-Jan-1995 rear calipers on another.
Seems like a good foundation for Ford to build their "Mondeo" world engine upon. I doubt a Vulcan V6 would cut it internationally. :)
I def. don't see the similarity between the Duratec and the InTech. You even mentioned one was 90* and the other was 60*. Thats a major diff. right there. But, tell me, which of the following dimemsions are most similar, and which one doesn't fit?
4.6L InTech
90.2 x 90
Duratec 25
82.4 x 79.5
Mazda KL
84.5 x 74.2
One of those definitely does not fit in. It appears to be the Modular. That's exactly what I meant when I said they changed the dimensions a litle bit so it wouldnt be an exact clone...
not to mention the bore spacing... modular and duratec? wildly different engines. The only thing they may share is the finger follower style valvetrain on the Ford/Mercury version. The modulars also have like the biggest cam base circle i've ever seen in my life, on any engine!! ***!
Just found this, yes it's wikipedia, but check out the listed predecessors and the successor to the orignal Duratec. http://en.wikipedia.org/wiki/Ford_Mondeo_V6_engine I didn't make it up.
Ford sure loved the aesthetic of the KL too ....
And of course, some of the Duratecs, esp the original 2.5L had the Yamaha SHO style intake manifold.
Don't forget to check out this Mazda 2.0L V6 (KF) in this Mondeo
over 2:1 rod stroke ratio? Thats F1 territory, buddy!
They would, wouldn't they? I'm sure they'd love to forget Mazda altogether too, now that theyve offloaded them and are scott free with what THEY need just in time for Japan to take it up the you know what in this economic crisis.
And there are lots of engines like this from a number of manufacturers.
BuickGN's 3.8L for example.
The 4.6L modular Ford found in the '03/'04 Cobra, will handle over 1,000RWHP on the stock internals no problem.
The 5.4L in the Ford GT.
The 5.4L in the Mustang GT500.
The Ford 427 SOHC from the sixties, 657HP bone stock.
The Ford BOSS 429
The Chrysler 426 HEMI
The aluminum-headed GM 427
The 340 Mopar
Ford's BOSS 302
Ford's 351 Cleveland
and the list goes on.....
Ah yes, the good old days. I used to have a Dodge company car with a 440 CI, engine, high rise aluminum intake, Carter 4B carb, and a decent set of headers. One gent higher up the ladder than me at the time had a Ford with the 427 OHC engine. It had a sealed(so we couldn't tinker with it) 6 barrel ceramic carb, big aluminum high rise and full headers. We had to take it to the ford dealer for all service and give it back to Ford at 50,000 miles, however, it never made it to 50,000.
My personal favorite was an aluminum head, aluminum high rise, full headers, real 4 speed Chevrolet. One bad dude.
It's too bad engines like the Ford 302, 351c and w, 460, 300-6, and engines like you mentioned, aren't still being produced with today's oils. Think about what oils they had back then in the 70's and 80's compared to now, and those trucks are still running. Makes ya wish you could have a brand new 70's or 80's truck in 2009. It'd last forever.
Well, you could always do what I did with the 440 I mentioned earlier- rebuild one and go. I expect it to outlive me, and I'm not particularly old or decrepit yet... Heck, I've been trying to outlive a 318 since I built it in the fall of '82, and if I continue to neglect it I just might win.
What will probably happen to the 440 is that I'll succumb to the urge to update it and tinker with another combination long before anything actually wears out.
The Ford BOSS 429
The 340 Mopar
Ford's BOSS 302
Here's one in a T-Bird:
Available over the parts counter, or as a dealer-installed item, they were never factory-fitted to any production Ford car.
Then you have that Monster Ford GAA.
1100CI, DOHC 32Valve V8, produced 1940-1950 specifically for the Sherman tank and its derivatives. Over 1000Ft/lbs from idle to 2600RPM. My favorite part is the cams driven off the crank by way of worm gears and a drive shaft..
